Hi there looking for some help/info regarding the antenna mod on the RM330 does this mod actually work better for signal ? Also what antennas are good for the mod on the rc 330 any help be great seen some YouTube videos but none really explain or test is signal is better. Thanks in advance ![]()
Which antenna mod please? There are loads to choose from ![]()
Have a look here
One where you have to drill holes into the case of that helps anyone mod really to improve signal
Thanks was there any improvement? As I have seen comments on videos some saying that is was more worse than the original
No, not really. Have you got a link you can share with us? ![]()
Is your current controller struggling with interference issues or something?
Here’s one of the links https://youtu.be/6jleBEUCc2Q?si=c2hbhaWcy0_3FeXO yeah I get a lot of signal interference when I am in a open park no houses about or trees
Thanks for the link!
Without knowing what dB gain those antennas are and without knowing the measured level of your signal interference it’s hard to say exactly how much they’ll help you.
But ![]()
By design they’ll be inherently better than the stock / factory setup.
Get drilling ![]()
Yeah I am thinking about it want antennas do they use or do you recommend any? I don’t really know much about antennas or that but willing to give it a go only thing I would be stuck at is what kind of antennas work best
I will find a link to the antennas I used… They worked great. Can’t prove performance in a scientific fashion, but going by flying the same routes before and after mod, both in CE and FCC modes.
@Emss I’ve sent you a PM
Mick, any chance you can share your experience with the rest of the readers ![]()
Please do @Stillight ![]()
I used…
Yes, I find the mod very good as it improves signal quality.
Fairly easy to do if you don’t mind taking your controller apart. It feels like you will break it pulling the thing apart.
Has anybody else had the bollocks to do it?
My PM to Emss was offering him a swap for his standard controller as I will probably sell my Mavic 3 classic with the stock controller.
He hasn’t replied yet.
