Ok, I’m on holiday up north and it’s coming to an end and as the weather has been ridiculous I’ve not had chance to get out with any gear. However this afternoon there was a lull in the rain and it gave way to a decent sunset. So I checked out the nats app to make sure all was ok territory wise and up went the drone.
However a couple of minutes later I was traveling over the hills and noticed that the wind was taking the drone when I wasn’t holding onto the controls, no issue I thought, I expected as much, so before letting it get too far I thought I’d bring it back.
So I turned it back on itself and towards me and but started to get a bit concerned when I noticed the distance reading was creeping higher and higher despite me giving it full beans in sport mode. I didn’t want a flyaway situation if I could avoid it so I faced the camera down and looked for a safe/decent enough place to access to land the drone. I found a playing field and went to land it by a set of goal posts, figuring I could just leave it sat there and take my phone with the map still active on the app. However as I dropped it to the floor it lost its signal and it poohed itself and went to return home mode by itself. At this point I panicked thinking that if it tried to return home it’l just get swept further away, however despite how it reacted to my controls originally, or rather didn’t, it shot straight back to the take off point with no issue whatsoever.
So my question is does the mavic motors even in sports mode save more juice in reserve for situations like this where they fight against stronger winds? There was a wind warning but it wasn’t any windier than a lot of the weather I’ve flown in before. Or is it possible that there was just a glitch between controller and drone that simply ignored my command to fly in the direction I chose?
