Land owner permission obtained.
Beautiful place to fly a drone. There is a convenient car park nearby from which to TOAL I and another drone owner actual TOALed with a short climb down from the bridge under which the falls passes.
If you fly here, there are several sets of falls you are going to want to get…below the bridge going into the ocean, and then at least two sets of falls above the bridge set amongst a beautiful grove of trees surrounding a pool.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 22/05/2024. It remains the responsibility of any pilot to check for any changes before flying at the same location.
