Nice clear day for a first flight with the Air 3S, with the YAM in the frame too ![]()
Like it. But how do you do it? Also I’m sure we used to go there motorcycle racing when I was younger. Does it still happen? Or is my memory even correct?
Do a Pano on the drone as normal, I then use Kuula to convert the file into a shareable image with zoom, and then just make a post on here under Pano by Drone section and paste the link, voila a 360 zoomable panorama.
Yes they used to do racing on there, this was also where Richard Hammond nearly died in a speed test crash
I’ve done a few trackdays there too
Thank you.
Hey up mate, cracking image, I’m learning abit already, I just downloaded the Kuula app ( or something very similar) for the 360 image to be converted, nice one mate ![]()
Just load up single image of Pano, then when shared on Kuula you will get an option to share yourself, select on the lef t the option for “ZOOM” and copy the embedded text and paste it in to your GA post
Nice 1 yorkie not been at yam for years need to get down again soon ![]()
