Hi : I have a Mavic Air, thought I try this Transmission FCC hack . Now only have a iPhone but borrow a friend android iPhone (Samsung Galaxy A6 ) have downloaded the Dji Go 4 App and Fake GPS App. Now this is where the problem starts : told to mock the GPS app on developer options on the android phone … found it … BUT on there just says ‘ Log output, show TTS output, and mode tree debugging , can’t find GPS MOCK ?? Am I looking at the wrong place ? On diff settings ?
Help please . Love to try new transmission
As far as I remember, when I used to do this with my Spark, after enabling mock GPS in the phones Developer settings you start the mock GPS APP and select any location on the other side of the Atlantic. Now fire up your drone as normal “but indoors as you don’t want a real GPS fix”. The GO4 APP should accept the false location and invite you to reset the WiFi settings. Wait for the WiFi to reboot and now you are in FCC mode. You can confirm this by looking at the WiFi channel allocation. On 2.4GHz you’ll have 11 channels instead of 13.
From now on every time you reboot your drone you’ll see the message about resetting WiFi, “CHOOSE CANCEL”. Accepting the message will revert your drone to CE spec’s.
If you want to permanently enable FCC there is software available. The easiest to use is Drone Hacks, though for many of the settings, including permanent FCC, there is a fee. There are other methods but if you’re not comfortable working with scripts in a terminal window there is a high risk of bricking your drone.
Yes. Developer options isn’t enabled by default. In settings you should have “about phone” or similar. In there will be “build number”. If you tap it nothing happens. Keep tapping it. After around 7 taps you’ll get a message saying words to the effect of “developer mode enabled” or "developer options enabled’ - something like that anyway.
