File your drone flight! 😤
Yup
Oh yeah, but it does allow others to see it’ll be busy!
Going back to the og post… If you’re there chatting to the guy you have a great chance of coordinating with each other to avoid each other! It’s actually quite hard for two drones (or drone and plane) to hit each other in 3d space when trying to do it, let alone by accident. If we was 100s of meters away and no way to chat then yeah I guess it ā€œcouldā€ happen. Wait 10 minutes go up yourself, have a chat, one goes one way one the other…
There is no requirement, and it gives you no extra rights. As said before if everyone logged one, then maybe it’d help, but unless enforced (don’t give the CAA ideas please), that won’t come close to happening IMO
Well - I guess you were only 0.6 miles from the airfield … they ain’t gonna cancel all flying for you, are they. :wink: :rofl:
I don’t recall a NOTAM being logged (I may be incorrect?) … just loads (and I mean … ā€œLOADSā€) … of flight reports logged, and I believe the gliding club was made aware.
am I over thinking this… it’s a drone… normally less that 1kg and of size 300x300x100mm…
do we not just have a chat with the other guys flying if we are concerned?
I forget how many drones we had in the air at the last meet… and other that some whatnot end (me) fpving a mini3 pro above the grasstops past a couple of involved persons and to the left (1 ~2m) of another drone at full throttle I don’t think we had any issues…
(I could clearly see where I was going and what was about)
… for everything else we generally had a nearby zone that everything non FPV was flying and then an outer ring (plus between the trees… all VLOS) where everything FPV flew…
I’m not being funny but it ain’t that hard to see where others are flying and come up with your own exclusion zone of where others are active and also your return to home landing path as part of a Dynamic Risk Assessment… :wink:
I’d be more than happy to meet someone when I’m out and about …
(please don’t give the CAA the idea we’ve got to book airspace and exclusion zones!). bit of a chat and VLOS flying is all that’s required
No, you’re not :blush:
Every time I put one in the air. Even if it’s only for ten minutes. Its good practice.
I personally briefed the pilots as they were strapping their parachutes on, the way I see it, the glider pilot was cocking a leg….
I think it’d have to be a f big drone to bring down a glider… I mean it’s got no engine to ingest the drone and it’s designed to well … glide!
at worst… I’m guessing it will dent a leading edge of a wing if it were big and heavy (DJI fpv?)
but then again… the flight rules are the flight rules… separation distances etc. VFR… they should be above 500ft except when landing or taking off
just wondering if any of them listed any near misses on that quarterly near miss log that’s always interesting to read… plane flying at FL290, co pilot thought he saw a 1m long cigar shaped drone 50m off the wing… … asked the pilot ā€œdid you see thatā€ (at 300mph…). ā€œsee what?ā€ā€¦ but following discussion… decided it must have been a drone… :thinking:
I’ll register a flight generally but not always.
If im hiking or somewhere rural there’s often not a phone or data signal to allow me to do so.
It’s good practice but not aways feasible. If its commercial or working with others then yes its normally a set time and/or place and ahead of time so easy. If im hiking in the hills and suddenly see something that looks nice i often cant do it.
Any time ive been flying around the same object as someone else (i) its pretty easy to find the operator and (ii) easy enough to have a chat to make sure we’re not in each others way.
Ive never yet had any negative experiences from other drone operators.
Yeah this.
Exactly as I said earlier heh. We’re in the same boat heh
