Hi - Just got the HDZero googles and I am havingf a hard time finding a set of stubbies in the UK. I am looking for 4x Truerc or Lumenier (RHCP SMA). Any help would be much appreciated !
Hi @sm606, it looks as though you’re quite new here ![]()
This is just the nature of things, you just get what you can or have to wait for stock. Best i could see was getting two packs of these as in stock RHCP SMB Stubbies.
If you’re after specific Luminear or TrueRC then you might need to get your name on a stock waiting list.
Also, Welcome to the Forum ![]()
Great - thanks! I am almost tempted to order from Aliexpress.
Cant beat @RestlessZombi recommendations.
Only others I could find:-
https://www.flyingtech.co.uk/fpv-camera-gimbals/vas-58ghz-victory-stubby-sma-antenna-rhcp-lhcp ?
5.8 GHz RP-SMA Stubby Antenna RHCP — CineStore (Not used them at all - Random google search)
I’ll vouch for FlyingTech I’ve used them loads ![]()
Also found these:
Only 1 pack of 4 left in RHCP it says for DJI but DJI are LHCP ![]()
ordered - thanks!
Glad I could help
I’ve used Kingquad in the past as well so can also vouch for their service as well ![]()
oops was a bit hasty - they are reverse sma - so will not work with the HDzero goggles. I have a lot to learn about this hobby
Amazon does adapter not pretty but they work whilst you wait for next batch.
How do I know this ?
I made the same error…
I did the same when ordering my first too.
EBay for the adapters there usually a couple of quid
I nearly posted they were RP and better check I know DJI backwards. You can use either RHCP or LHCP with DJI but make sure the right connector, I assume HDZero the other way round.
Better not use an adaptor (adds a little resistance), see if you can cancel?
Yep asking them to cancel and refund - thanks!
Rubbish negligible resistance negligible dB loss.
If quality product, decent material and screwed tightly then yes, but any loss on something he can cancel and await better (no need for them), the better. But a decent straight adapter would be less <0.1db I guess ![]()
