Stunning Frank
Cheers Steve
Top video! Love it at 2:43 when the seal appears to casually waves up at the drone!
Haha yes it does. Cheers Tony
You might want to consider a gimbal re-calibration … because the horizon seems a little off in a few places …
The vid gets my seal of approval, though .
Yes Dave I’ve noticed that. Never done a one before is it in the Go4 app or DJI assist?
Definitely in the Go4 app … the three dots at top right, then select the gimbal icon, and it’s in there somewhere.
Only done one once (or twice) after removing/replacing my gimbal.
Also - I know I’ve inadvertently caught the button/wheel combo (can’t recall what that is. LOL) that enables you to roll the camera horizon … took me a while, whilst in Italy on a long holiday, to find that one and correct it. That might be all it needs. Worth checking on the kitchen table … if it powers up with horizontal things horizontal, then that was probably the cause and a re-cal isn’t needed.
Thanks mate will have a look at that.
It was a long time back but I had a little argument with a tree and the gimbal wouldn’t be level after powering up the drone but after waggling the gimbal around while turned off seemed to fix it. Hopefully it’s not damaged.
Stunning shots there Frank. Love the intial shots of the mist over the sea and land and the seal footage is captivating. Big thumbs up from me.
C2 + Right Wheel is ringing a bell?
Could be - rarely use it. Actually, I make a point of not using it so that I keep my fingers clear from accidentally nudging it.
Just knowing it’s somewhere should I need it is enough for me. LOL!
Chances are, whilst actually flying, the correct fingers would find the correct buttons/wheels.
Just trying to find it with the wheel tried c2 and wheel not working though.
Thank you Steve.
Very nicely done.
Thank you Paul
