Trying to view anything on my S9+ when attached to the controller is a utterly pointless.
I’ve looked at all sorts of attachments to raise the screen etc.
Can anyone suggest a good remedy for this problem?
What exact problem are you having mate? Glare?
If it’s to do with brightness, Samsung’s only reach peak brightness when automatic is set to on.
Hi
I have tried a few and now using the one in the link below, it’s a bit like the Mavmount, but a hell of a lot cheaper. I use it with my 8" Asus Zenpad, but would work with your S9+.
I was using my S8 but found it too small as I could not read the warnings that come up, so hence the 8" tab.
https://www.amazon.co.uk/gp/product/B072BK4JQ4/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
I also put a matte screen protector on the tab, this has stopped all the reflections and then got a sun guard which needed a bit of modification, but it does the job.
Sorry, yes glare. All I can see is my face lol
I use this one as well with the iPad Pro
Thanks for that
Set your brightness to max and then make sure auto brightness is switched on. Without Auto brightness it will never hit its peak.
I use a shade like this on ipad but you’d need to choose size that suits your phone.
https://www.amazon.co.uk/gp/product/B06XRXQJNP/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
That and a mount like the guys suggested should make a big difference.
