Its funny you should mention the camera on a pole but my friend pat from the film club, was just showing a tiny 360 camera on a pole but due to the angle you can not see the person or pole underneath the camera.
Any (legit) business asking you to do work for them should ask for risk assessments for the work you are doing, and said RA should include what insurance cover you hold.
Imagine a flyaway that sends the full school bus over the cliff into the dogs home exploding on impact (extreme I know but its an example I like)
First thing to do is call the ATC at Manchester Airport.
Tell them:
- What you want to do
- Where you want to do it (in case itâs inside their FRZ)
- When you want to do it.
They can tell you if itâs inside the FRZ within seconds if you give them the âwhat three wordsâ or map reference. Donât use a post code as that could cover a large area.
If you are just inside and at a none busy time, they might give you permission to do it there and in that time slot. - Get some insurance, even a M2 could kill somebody if it fell from 200 feet or so and hit their head!
- Donât forget, if youâre going around a building, youll need a spotter for the back side, or youâll have to go around with it. Most office blocks are just steel with brick on the outside, bad news for transmission and control signals.
- Get some proper training and learn the rules before you do anything (Once again see Article 241)
The most important thing though is contact ATC, theyâre in charge of that airspace, and if they say no, donât do it!
âŚto make sure your RTH height is set higher than the building
That as well!,
Just in case
Havenât took my GVC exam yet, canât remember everything!
No, the first thing you do is find the phone number for Manchester ATC. Iâm outside but right near it myself, so figured it would be good to have handy just in case. It seems that they donât make it easy to find the actual number, rather than links to airport info and such.
https://www.aurora.nats.co.uk/htmlAIP/Publications/2020-12-31-AIRAC/html/index-en-GB.html
Fair warning - this page doesnât play nicely on mobile. Choose aerodromes from the left menu. ALL UK aerodromes with ATC are listed
This site has all of the details you need, for smaller airfields. For major ones use the NATS site as above.
Ah, thanks for that. Thatâs exactly the page I was looking for earlier, but it must have been in the transition period around 1-5 Jan., because Iâd seen that I should look for an âaerodromeâ link there, but it just wasnât there then.
And that is the same number I dug up elsewhere, somewhere, canât remember just how I finally got to it now.
