Mavic Pro with controller and three original batteries, eight PolarPro filters, a Freewell 10-stop ND filter and some Neweer filters all of which have seen little use
Extra props, landing feet and an unopened set of prop guards (not pictured)
Charger unit plus car charger (in box)
Three controller cables (only the iOS cable has been used)
Complete with handy (semi-hard) carrying case
I’ve recently purchased an Air 2s and a Mini 2 hence finally parting with my first drone.
FULL DISCLOSURE: I had a crash a couple of months ago which left one rear arm hanging. Everything else looked OK to me but the repairers felt both rear arms should be replaced. DJI authorised repairers Drone Doctor UK repaired it for me and provided this diagnosis …
I’ve examined your DJI Mavic Pro and I can report the following damage. Both rear motor arms are structurally damaged (End stop mounts broken) and will need to be replaced. The middle frame is also damaged at the rear left motor arm housing and will need to be replaced. All other functions have checked out OK on the bench test and visual examination.
So, it’s been recently serviced and repaired, comes with three batteries and a case with some rather nice PolarPro filters.
I’m looking for £350 plus postage
Collection from Elland, West Yorkshire or if you would prefer me to send via Royal Mail/ParcelForce I’m happy to do so at cost.
