Found a drone in North Wales, near Yr Hafod
I was out doing some mountain training over the weekend and came across a drone with the Flyer ID and a name on it.
The flyer ID is (I think) GBR-RP-N3LBBV4KKVN9. The paper label is water damaged so I’m taking my best guess.
It’s a Mini 2 SE. Still has it’s SD card in it.
Happy to send back to the owner if they’re on here :slight_smile:
Hi @camchalmers ,
The sticker should be the Operator ID and not the Flyer ID.
If the paper label has water damage on it, it sounds like it might have been lost a while ago. What is the condition of the drone? Is there any grime/dirt/stains on it that makes it look like it was lost in the last 24 hours or several months ago? If it has been outside for a while and it has rained, the drone may be beyond repair.
Even if the drone is beyond repair, the SD card may well still be in tact. That’s probably more important I would have thought…IMHO
May be worth checking the SD card as many owners put a text file containing contact number just in case of loss.
Or check the exif on any photos on there, you never know
That would be good, but does it have one and what size is it, and what speed.
The right thing to do is to hand it into the local police so that they can put in their Lost & Found box. Or contact the CAA to see if they care. In reality though, if I lost my drone and couldn’t find it, I am not going to the local police station to see if anybody handed it in, then contact them every week or month to see if anybody has now handed it in. If it has been outside while it has rained a few times, I know it will be toast and I won’t want it back. That is for a pre-build drone. If I built my own drone, then I would want it back as I could still use the frame and possibly other parts.
That’s a darn good idea, I never thought about doing that.
I recovered my Avata 2 from around 5 ft under water and the SD card as fine.
Might also be worth checking inside the battery compartment for a phone number.
The number on the drone is an Operator ID
You can check if it’s valid via the CAA website but it won’t provide user contact details!
If you (original post) take the drone to the police, they have access to the operator’s contact details - we don’t.
Thanks for posting​:+1:
Don’t you need the owner’s name to check whether it’s a valid ID?
Operator ID’s begin GBR-OP Flyer ID’s begin
GBR-RP :man_shrugging:
Yes you do
I did think that, but the label says Flyer ID and not Operator ID, and it’s definitely a Flyer ID as Operator starts GBR-OR.
No sign of an Operator ID on it
no sign of the operator ID, only the flyer ID
Quick update, tried the SD card and works fine and has drone footage all the way back to 2024. Looks like the final clip was 7th August 2026.
Any exif on any stills that may give a home location?
I’m doing a backup first on the slim chance the person finds this post, and then I’ll check :+1:
Edit: lots of EXIF data but all holidays snaps. There is some footage of their car, a wrapped Infiniti though
OK - then the person flying it when it went down is up a creek without a paddle I guess…The label should have been their Operator ID​:+1:
I’ve searched the name to see if I could come across anywhere on socials, and have found him on Facebook and insta so popped some messages across and hopefully he responds!
