Looking to build budget 4s fpv drone and looking for some good motors, not looking for a mad amount of power just enough to pull of a sharp power loop or two and that should be plenty. Found some craze pony motors from Amazon for £35 but not sure if they’ll be good enough? Anyone got some suggestions?
They may not be the cheapest in the world but EMAX ECO II series have earned a reputation as the best value budget motors
FWIW
iFlight Xing are a decent motor as well
I’ve got several drones using these. Great performance and decent £
Hmm, yeah they look good. I got speedybee’s new f7 V3 30mm flight stack and a 50amp esc so I think it should have some punch to it! So looking for some motors that are a good match but not too pricey, found the motors your talking about for £11 a motor. Not bad really and they look good
Thanks for that as well! I consider the two and see if there are any benefits too them with my specific setup
I’d give another vote for the emax eco II. Solid too.
I’m with Dean most of mine run on xing can’t fault them, what ever you decide on stick with them then you can chop and change when you crash .
