This is an excellent open space to fly with excellent panoramic views of Birmingham.
I've put the pin the lay-by to park. A short walk through a gate to access a public footpath. You can either go downhill, or go through to the NT owned Frankly Beeches which is the actual high point. Obviously with the drone it don't make much difference if you TOAL from either side other than being able to keep VLOS behind the trees.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 28/03/2022. It remains the responsibility of any pilot to check for any changes before flying at the same location.
