Weather permitting this weekend, I’ll hopefully have my attempt posted.
Not flown at all since October last year. ![]()
Ah maybe we can expect some of this then ![]()
Let’s hope not, I’ve spent hours and hours over the last few months, modifying my quads and playing on the simulators.
Which sims you using Jay?
This Challenge Shall Be Closing Off Tonight @ 8pm Ish For Voting !
Not had the opportunity to fly this weekend. ![]()
It was too windy for whoop on Saturday at the east coast and today’s out the question at home.
The FPV Challenge is now closed to entries - so it’s time to vote for your favourite, You have three votes each & they are in no particular order set out below, ’ DO NOT VOTE ‘ for your own entry or it will be disqualified, the poll closes at 22:00 on Tuesday 10th March when you will find out who has taken the top place !
First Place Winner Gets To Choose The Next Challenge, so while the poll is running it maybe worth all those that entered having a think about what challenge you may set if you win so we can then get the new one up & running asap,
however, should there be a tie a poll shall be set up for a further 24 hours to cast first place winner,
Good Luck All ! ![]()
congrats @DodgerFPV ! ![]()
Thanks for all the many many votes
Lets try and keep things simple but also fun soooooooo the next challenge will be THE PERCH
Find somewhere to PERCH
Remember the more interesting and risky the PERCH the better
Disarm when you have PERCHED re arm then take off simple eh
Have fun
OOH like the sound of this but eeek
Maybe a bit more expansion on the rules - does the perch need to take place when the drone is in Manual mode - so as to rule out Avata/Avata2 / DJI FPV being flown in normal / sports mode but cool if they are in Manual mode and you do the unarmed - mmm thinking about this a bit more not sure if them drones can be disarmed in flight like a true FPV can be…
Sorry rambling here - need to give it a go and see but I am sure they cant.
Something to test with an easy to access perch
– pretty sure I remember the most common BLHELI32 firmware (the one before last) has this issue where you cannot re-arm without cycling the power (physically disconnect/reconnect the battery). This was ‘the big issue’ when BLHELI32 went under as loads of ESC built with this version around but no way now to update/fix them
Nope any mode/drone will do
Send it I’ve done it myself with the Avata sensors unplugged remember goggles osd recording or remote screen needs an SD CARD also remember auto record needs to be OFF ![]()
The Daredevil Disarm (next challenge)
Perch/Land 1st then disarm and re arm
What about being stuck - I mean ‘perched’ in a tree… will that count? (this could be our most popular challenge ever
Well done @DodgerFPV ![]()
Sorry for the late reply !
Well done Drew @DodgerFPV ![]()
