Interesting read on everyone’s TPU print settings, I’ve only just started with TPU, bought a roll to print something for the kitchen.
The first thing I printed was the Cree Mount for the FPV drone…Pic.
I thought I’d try the PLA profile on my printer and to my amazement it printed perfectly….
Temp / 215
Bed / 43
Cooling / 2nd layer 25%
Retraction 2.2mm
Retraction speed 160mm/sec
Print speed 46.7mm/sec
Thingiverse printer upgrades … Place your model 3d printer in the search bar , then choose an upgrade… Reading the settings you put your printer on, then start printing … good way to learn …
You have 2 types ender 3 v2 and ender 3 v2 neo. While both printers use the same Bowden-style extruder mounted on the left side of the gantry, the Ender 3 V2 Neo is equipped with a metal extruder, which provides more consistent extrusion force and reduces the risk of under-extrusion.
best thing to do to learn the ropes is like stated above print upgrades for your model printer. My first printer the ender 3 pro has loads of upgrades to print on Thingiverse. things like tool holders and drawers, filament guides and rollers etc etc. Will help you get used to thinking the 3D print way. orientation of the part on the build plate is extremely important. overhangs and supports are all things that need thinking about.
yeah, trial and error mate. The spool itself should a have a sticker on it with the temps as well All brands have a different temp range my rule of thumb is 60 for the bed for PLA and I tend to go somewhere in the middle of the range for the particular brand and adjust up and down by 5 degrees till it prints right.
