Are you saying this has only started happening since the firmware update?
I’m not familiar with the Air controller, does it have a wheel to tilt the gimbal? If so, what range does that offer? And does the controller need calibrating?
(Ignore all that if the Air 2 has no gimbal wheel on the controller)
Yes slight left and right, if i press function it points down and shows 0° left/right, but then when i press function again it returns to horizontal but left or right never return to 0°
