Gyroflow Discussion Thread. Tips and help
After playing around with gyroflow, I’ve been wondering what other users settings are.
I’m using pretty much stock settings, apart from the imu orientation (YxZ) and lens profile. I use a walksnail profile -
caddx_Avatar-pro_wide__1080p_16by9_1920x1080-60.01fps.zip (825 Bytes)
I’m losing resolution in my output video, which is understandable due to the way it works. Just wondering if there is a way to optimise it.
Also, do more sync points really help? What are your filter settings, zoom and smoothness too?
I thought your comparison video you posted was really good Karl. Have to say I didn’t really think that stabilised fpv video would be of much benefit but it really does make a difference looking at Yours and Richards videos
With WS, yes, add loads of sync points… The timing of the gyro data and video can go out of sync loads.
With my short 1 minute videos I had 20 sync points. For much longer increase a lot.
On the JB video recently they had 500, I think. That is a silly number and will take ages to process.
Zero filtering. Zoom quite slow maybe 2 seconds.
The fov just enough to get rid of the red bars on the video.
The camera profile only affects the fish eye reduction.
Yes lots of sync points - go crazy.
I tend to use no zoom and let the edge be filled in to with repeated pixels.
I am just playing with you test video and putting key frames - so it does not zoom when you go for the tree dive. I’ll play for a bit.
Based upon @notveryprettyboy videos, I wanted to see what was possible with WS and gyroflow and playing around with setting.
Some options for Gyroflow on a real video (alot of youtube stabilised doe snot pass the sniff test)
0 - Raw video
1 - Vanilla smoothing
2 - Key framing out parts to make a dive not smooth and landing more authentic. With lots of sync points (30 and search 10 s for sync point)
3 - Switching zoom off (Repeat edge pixels) (Keeps resolution up)
IMHO - I think gyroflow is similar output to runcam thumb. With WS the view whilst flying is obviously excellent.
Worth using the dev version - so much better.
Now available on iOS
Sorry all if this has been answered.
When puting 10 bit into gyroflow why do i get 8 bit out
Have a read of this
Epic support there my friend.
Turns out h264 is only 8bit
H265 it is then
