Harlow Hill Water Tower, Harrogate - Added to Historic Buildings in Yorkshire and the Humber
Harlow Hill Tower is a historic building in Harrogate, a town in North Yorkshire, in England.
The building was constructed as an observatory in 1829. It is on the edge of Harlow Moor and was built for John Thompson. It was open to the public as a viewing point by 1900, but was only fitted out with a permanent telescope in 1933.
In 1998, a Foucault pendulum was installed inside. The building has been grade II listed since 1949.
The tower is built of stone, with a square plan, and is generally said to be 90 feet (27 m) high, although the Harrogate Civic Society states that it has been measured as only 70 feet (21 m) high.
On the top is a modern domed observatory roof. It has no decoration other than a lintel inscribed “HARLOW-HILL TOWER 1829”. The only windows are small panes on each side near the top. Adjacent is a two-storey entrance extension with a tile roof, and steps leading up to an upper floor doorway.
Interesting little site. I went there to run a practice maintenance survey.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 31/01/2026. It remains the responsibility of any pilot to check for any changes before flying at the same location. Landowner permission may be required before taking off.
Thanks for adding to the map @Keltoi, a rare and unusual building :smiley:
