Hi there,
I had a meeting of my Mavic Pro and a large bush, I had been playing with the settings and flying at 15 my’s it was coming back to me from 500 Mts’ flat out! when it was 30 Mts’ away I released the the throttle expecting it to stop easy, it over shot and when doing about 5 mph crashed into a bush! Rolling gently down the bush to land on long grass.
It seemed fine but I packed up and went home, I was setting it up on the table I took off the propellers so I could just the braking setting it at 130 now, I had been adjusting the yaw and braking to make the recording smoother.
The point is it was a soft crash and looked fine! but when I was putting the propellers on I found one had two fixing claws shaped off !! the thing is if you crash check the propeller fixing claws.
