Horkstow Bridge. I took this a while ago now I spotted it as I was visiting the area and stood out due to it being a suspension bridge. Was built in 1836 and is a grade 2 listed building. There are small areas at either side of the bridge where you can TOAL also park if in a car. You can even cross it in your car but I didn’t fancy it, all them wooden beams ![]()
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 22/03/2023. It remains the responsibility of any pilot to check for any changes before flying at the same location.
