How to download flight data from RC2 to my PC?
Sorry, couldn’t immediately see this in a search.
I need to download flight data in .txt format from my RC2 to my PC, any easy instructions?
I’ve tried a few youtube and google searches, but nothing makes it obvious (I’m probably being thick!)
Thanks in advance!
I believe it simply mounts as an external drive when you plug it in, and its then just a case of navigating through the folders to find the flight data. I can’t remember the full path off the top of my head but I was able to find it quite quickly when manually going through the folders the other day. One will contain txt files for all of your flights.
Google says
To download flight data in .txt format from your DJI RC 2 to your PC, connect the RC 2 to your computer with a USB cable, access the DJI Flight Records through the DJI app or file explorer, and then copy the desired .txt files to your PC.
Ah you see I tried various things and went through all the folders, but couldn’t see the flight data files. Oddly, have then just searched for .txt files, they all appear. Thank you!
Finally tracked them down here This PC\DJI RC 2\Internal shared storage\Android\data\dji.go.v5\files\FlightRecord
Thanks folks.
