How to enable green attitude line on RC2?
Weird. Not for me … random
Isn’t it something to do with FPV Mode or Follow Mode in …Control\Gimbal?
Hi @BossBob, it looks as though you’re quite new here :wave:t2:
This is from DJI and it worked for me.
Please select the (…), select Control > Button Customisation, and please make sure Hold C1 Right Dial is on Gimbal Roll. You may refer to the below link. Do take note that this feature will only be available on manual control.
I think its only available on mini 5 pro for some reason
I think it’s because of this:
Its disappeared for me with the lastest firmware…
Now im gona have to read stuff to figure it out :wink:
Same but I do get a horizon line back as soon as I rotate the gimbal away from 0°.
Yup,
I get that too maybe thats how it was intended to work from the start.
I’m having the same issue. Please inform if you find a solution. I will do the same.
Do this: To enable this line, in the RC custom buttons, when setting (C1+right dial/C2+right dial) as gimbal roll; or (right dial) as gimbal roll, the level will be displayed.
