Crashed inspire one. Can’t get props ordered 2 sets and they don’t fit. Can you upgrade the hubs to take different props.
Is it an Inspire 1 or an Inspire 1 v2?
I modded my motors to take quick release props, some pictures and details here:
I later swapped the entire motor out for something more powerful.
It was about five years ago now though, parts these days are probably quite hard to find Bruce @Skitz ![]()
Show us what you want, I might have some spares.
I’ve got:
A full set of early “screw on” 1345 props.
A full set of mk2 “push and twist” 1345s in Carbon fibre.
11 mk2 “push and twist” (6 black, 5 white) 1345s (standard DJI
24 propeller locks for the screw on props (6 full sets)
A full set of adaptors for the mk2 props (convert screw ons to push and twist)
I would take all of the 1345s props how much.
Hi Bruce, what sort do you need, the push ons won’t fit the screw type and vice versa, you’d have to use the adaptors for the screw motors to carry the push and twists. I think the Inspire 1 only uses 1345s.
Screw on blades, £10
The CF blades cost me over £50 and they’re unused, so £30
The push and twist props £30
The prop locks for the screw ons, (stop the blades flying off) cost me £30, so £15
Adaptors £10, includes screws to fit and the springs to hold blades in place.
These are all my spares for my Inspires although my main one uses the later push on and lock onto motor props
John
Thanks John
My inspired uses the push and lock. But I bought some and they are too small for the hubs and was told that they are Ty h he r S model. Or does the adapter fit and then I could use the S model props.
Has my inspire for some time first time I crashed and then what I thought was spare props don’t fit.
Maybe I should just start with the adapter s
Stick a photo up so I can see exactly what you’ve got and what you need. It’s a waste of time and money for you to just try anything in the hope it fits.
The adaptors just take the place of the screw fittings for the mk1 blades and screw onto the top of the motors instead.
The adaptors are for changing the original screw on blades to that configuration
