Right so some of you may know or not, i mentioned a while back about the Mini 4 Pro been really skitish when using the sticks Left/Right Etc.
So today i thought Try the other controller for the Air 3, eliminate where poss, got this message
Anyways put the Mini 4 in the air and still skittish, no matter what settings i use, even in Cine mode it’s all over the place, so next step,factory reset the whole lot and start again. Could it be because i’m used to the weight of the Air 3
It will most likely be me, but at the mo i’m not impressed with the 4
Mine was because of the obstacle avoidance, when its set to bypass it’s really skittish turning on nifty mode helped smooth it out. setting it to break made it super smooth but nifty mode was a happy medium for me
