Hi can anyone tell me if this sd card be used with the dji mini 2 in 4k? when i attempt to record in 4k it starts to record then says full, the sd card is going into drone, i think the write speed is to slow?
Nextbase 128gb pro micro sd xc u3 v30
The markings would suggest yes it should work
Where did you buy it from.
hi cant remember, but i think the read speed 100mb/s write is 60mb/s i thought the write had to be 100mb/s for 4k, maybe i am wrong
DJI mini 3 Pro for intance requires an SD card that must have a writing speed of at least 30MB/s to handle the 4K resolution recordings of the drone. My recommendation is to use Sandisk TBH as they have been rock solid for me (providing they are genuine of course). Cheap at mo!
SanDisk 256GB Extreme PRO microSDXC card + SD adapter + RescuePro Deluxe ,up to 200 MB/s, with A2 App Performance, for smartphones, action cameras or drones UHS-I Class 10 U3 V30
DJI Mini 2 - Specifications - DJI?
UHS-I Speed Class 3 or above is required. A list of recommended microSD cards can be found below.
16 GB: SanDisk Extreme
32 GB: Samsung Pro Endurance, Samsung Evo Plus, SanDisk Industrial, SanDisk Extreme V30 A1, SanDisk Extreme V30 A2, SanDisk Extreme Pro V30 A1, SanDisk Extreme Pro V30 A2, Lexar 633x, Lexar 667x
64 GB: Samsung Pro Endurance, Samsung Evo Plus, SanDisk Extreme V30 A2, Lexar 633x, Lexar 667x, Lexar 1000x, Lexar High Endurance, Toshiba EXCERIA M303 V30 A1, Netac Pro V30 A1, Kingston Canvas Go!Plus V30 A2 microSDXCS
128 GB: Samsung Evo Plus, SanDisk Extreme V30 A2, SanDisk Extreme Plus V30 A1, SanDisk Extreme Plus V30 A2, Lexar 633x, Lexar 667x, Lexar 1000x, Lexar High Endurance, Toshiba EXCERIA M303 V30 A1, Netac Pro V30 A1, Kingston Canvas Go!Plus V30 A2 microSDXCS
256 GB: SanDisk Extreme V30 A2, Samsung PRO Plus V30 A2 microSDXC
it “should” work, although it does not have the A1 or A2 rating
this is also useful to understand, hence looking for the A1/A2 rating is also important
getting a card that is too high spec can sometimes be a problem too…
