I’m still having a slight issue with the throttle range, when I go into auto launch mode, I only have to raise the throttle a tiny bit for the motor to be way to high. Further more when you simulate the second stage of the launch the motor absolutely screams and when stopped it feels warm even though its only ran for a few seconds .
I understand I can alter the Launch Throttle in INAV but once in the air will the throttle scale drop back to a normal range?.
Have you set your idle throttle and launch throttle as discussed along with a hand held hover test? If you have then what you are describing sounds as if it is ESC calibration
But I thought you were running DSHOT 150 or 300 which do not need calibrating
Perhaps you need to use BLHeli configurator to reset the ESC’s to factory default.
Yah iv turned my throttles launch down to 1500 still feels like it has enough thrust, and yah using DShot 300 but will look into defaulting in BLHeli …good shout
If you flick them over that would be great , I don’t think I’ll be going anywhere for a few days due to being sick… wouldn’t won’t to pass that on to you mate but thank you for the offer
