Was a bit Wobbly due to using the shockingly bad Dji controller
I’m actually quite impressed with the quality
What’s the refresh rate like in the real world? Did you find it ok James?
@PingSpike the refresh rate is the display is absolutely fine. It gives you a lag readout in the osd and it hovered around 25-30ms. Tbh I never noticed any lag at all.
Top tip… don’t get the flymore package as the Dji controller sucks so bad compared to my Taranis.
As soon as they make a ‘Mini’ version for Toothpick class - I’m in
When I finally get mine working on the Cygnet (
) - the latency will be lower than the standard camera! - A split mini 2 - (38ms) , which I don’t notice anyway ![]()
