ohhh my good i done it few month back i buy mavic pro so i always try fly proper way and after some trening i passed my a2 cofc just few minutes ago
Nice
Interested for a feel of How hard or easy ?
O Level/GCSE type level or more a quick trivia revision test ?
Latter
Anyone flying a couple of years could probably pass with no prior sight of a paper
If it helps gauge the difficulty, nobody in the history of A2 CofC tests has ever failed ![]()
it’s was ok i go through uavhub course and enjoyed learning,a lot question are from different topics air law,meteorology,etc and somone said if you fly long enough you pass i don’t think so as questions are more technical ,but afcourse any can try luck pass mark it’s 80 procent from 30 questions and i make some mistakes.
Well done
I used UAVHub…. Did the learning, and did the practice test many times … until I didn’t need to actually read the whole question to know what the answer was.
Did the test, and it was simple ![]()
Exactly the same here! 100% in around nine minutes. When I said I had finished, the Proctor asked if I wanted to check anything but with a 100 showing on the screen I said no thanks and that was that. I did wonder shortly afterwards if I had missed anything!
Seemed easier than the EASA A1-A3.
Big shout for UAVHub!
I did the UAVhub one as well. The mock exams are of the same level as the real one and you can do the mocks as many times as you like. If you can consistently get 95% on the mocks you will have no problem with the actual exam. It’s more of a faff to set up the proctor, than it is to do the exam.
I just passed my A2 CofC today with ‘Pigs can Fly’ (little shout out). Just wanted to agree with the others on here you really shouldn’t fail and not difficult to pass. I’ve only been flying for 2-3 months and it took 30 minutes. So if you’re thinking about taking the test I wouldn’t worry about it. ![]()
Hi
I have just enrolled on the E learning course with a view to booking the exam in a couple of weeks
I took the mock without even reading a page and failed! But with 63% so that was promising
I already had my flyer and op I.D. so had read through all that anyway
Pah I literally just did the test and passed after taking about 6 mins BUT I messed up the 360 video so I expect it to be voided - Luckily I get another go and I won’t mess it up next time!
I was passed - no void got my Cert at 8am ![]()
Well done that’s good news, just out of interest, i have done the mock exam a few times now and I wondered if I was doing the right thing? Does the actual test vary by much from the mock? should I not bother doing the mock again?
I only did the Mock once - And no I don’t think so - there were a few about the Weather but it was all covered. It does say the questions are all pulled from a larger Databank but I did my mock about 4 hours before I took the Exam. You should apply for the exam right now and then do it when you are ready. I also don’t think there is a rule to say you can’t do a Mock right before you do the real exam.
Good luck. You get 75 mins but you might well do it faster. You also get another go included in the fee - but you won’t fail ![]()
Just remember when you get to do the video you have 1 minute to read and 2 minutes to do a 360 of the room you are in and also and showing your desk and under it.
