One of the recommended SD cards, as per O4 Pro specs, is Kingston Canvas Go Plus.
I bought three of these but none of them work on the air unit (they do work in my goggles N3).
No matter what video quality I set for recording, the air unit always throws “sd card error”.
Other SD cards I have work fine up to 4K 60 fps, but I haven’t managed to record at 100 or 120 fps yet as they are too slow. I guess I will have to try with more expensive sd cards?
I can vouch for the sandisk extreme pro cards and the non pro both work great I’ve got them in all my tech. Usually pick up a few in the black friday deals every year as you can never have to many.
I just bought a few of the amazon basics ones, they’re rapid. Copying off at over 100MB/s which was plenty for me pulling content off the o4 pro. Edit: just re-read you want 4k 100fps. Not tried it yet but think it should be fine.
The 4k60 h265 content was about 1GB/min so the 4k100 could be say 2GB/min meaning sustained write speeds of 30MB/s - should be easy for these cards, no?
I always now use Sandisk, never had a problem. Did try Kingson compact flash in my camera, tbh it was utterly crap, I tried another make (can,t remember which, but that had issues too. Lesson learnt- Stick To Sandisk, in almost 20 yrs of digital photography I’ve never had a single problem with Sandisk. Get the fastest you can to avoid buffering issues.
