Legality of flying *near to* "assemblies of people" in A1 (with a sub 250g drone or a sub 900g UK0/UK1/C0,C1 drone)
As always, the answers are there in the Code if people can be bothered to read it! :woman_facepalming:t3:
And don’t be a dick!
But this isn’t talking about the A1 category. This is talking about special authorisation for drones between 250g and 25kg.
"You can fly a drone or model aircraft that’s below 250g, or UK0,
UK1 or C0 class closer to people than 50m and you can fly over
them. From 1 January 2026 until 31 December 2027, you can
also fly a C1 class drone or model aircraft closer to people than
50m and you can fly over them.
You still can’t fly over crowds
Where do they say please with respect to sub-250g drones? I can’t find it
I saw this. Have the rules changes since this video was made?
If you read my post above it says :-
The rules on minimum distances to people are different for drones and model aircraft below 250g, or UK0, UK1, C0 or C1 class.
You can fly a drone or model aircraft that’s below 250g, or UK0,UK1 or C0 class closer to people than 50m and you can fly over them. From 1 January 2026 until 31 December 2027, you can also fly a C1 class drone or model aircraft closer to people than 50m and you can fly over them.
You still can’t fly over crowds.
Remember, you must never put people in danger. Even small drones and model aircraft could injure people if you don’t fly them safely.
I know you can fly closer to people, I can fly my C2 Mavic 3 pro within 5 metres of uninvolved people if it’s in slow speed as I have an A2 CofC.
The post your linklng to was a reply to @GreenAJ about flying over crowds!
The simple answer is “Don’t be a Dick”
That’s right, but it was also a follow-up to my previous post where I only offered up the 1:1 rule as something you could turn to if you needed to codify the general rule which is, as @Rocket says, “don’t be a dick”.
If you’re looking for somebody to tell you the CAA haven’t specified a minimum distance from crowds and it’s therefore ok to fly right up to them, I’m not your somebody.
Not sure if you mean Specific authorisations from the CAA to gain authorisation to fly over people or just flying in the Open cat. But watching the video above, the CAA guy clearly states in the A1 Open cat, people are to keep the minimum distance of 50m from an assembly of people and gives examples. He also stated that if flying higher than 50m to use the 1:1 rule, so 60m keep 6om away etc. I also understand that video refers to the incident that occurred in May this year so there should be no doubt as to the validity of the issue.
Moreover, the distance involved should also be dynamically assessed and increased, if there are high winds, inclement weather, or any factor that should be considered by a rational person, before, or during, normal flight.
Would it be safe to fly a drone, say, 20m horizontally from a crowd, assuming there was very little breeze and the drone was a DJI Mini 5 Pro?? Or would that be bring “a dick”?
Using the 1-1 rule as your guide, you can be as little as 20 meters away from a crowd IF you are no higher than 20 meters above the ground.
Match your distance to your height.
If you are 80 meters high, stay 80 meters away.
