Legality of flying *near to* "assemblies of people" in A1 (with a sub 250g drone or a sub 900g UK0/UK1/C0,C1 drone)
Legality of flying near to “assemblies of people” in A1 (with a sub 250g drone or a sub 900g UK0/UK1/C0,C1 drone)
I realise drones are not allowed to fly over “assemblies of people”, but is legal to fly a drone near to an assembly?
Is it the case that you used to have to keep at least 50m away (or if you were higher than 50m, the same horizontal distance) from an assembly of people, but this is no longer the law.
Thank you in advance.
The overbearing point of the drone code is “don’t put people in danger”
So whilst the code doesn’t actually state a minimum distance to keep from crowds, and leaves it open to interpretation, your interpretation really should be viewed through the lens of “am I putting people in danger by flying here?” And if the answer is yes, move further away.
I think what the CAA worries about is what happens if your drone falls into a crowd of people who cannot move out of the way, and I believe their definition of ‘crowd’ for this purpose is where there are less than 6’ of space between people on average. This allows flying of sub-250g drones over relatively densely grouped people; an average shopping centre, for example, does not have people that densely packed. But a football stadium, or the crowds going to or from the game, does. As a general rule, good practice is to stay away from people, and stay further away from more people… In practice, this will require continuous live risk assessment in real time as crowds gather and disperse. There is usually somewhere you can stand off, over a building or wooded area, to avoid flying directly over them.
Source ?
And much heavier drones too
Hi, I agree. How much you are all saying is how you interpret the distance between people or groups. But in the cold like a day like someone just said through the lens of your drone. You’re by there and it’s perfect. Known around no worries. Then 10 minutes. Things change where there was one person or none at all. There is now a large group. Problem advisors is that to get to a more safer environment. Which doesn’t mean causing any problems with the civilians around you might. Have to fly maybe there are trees or buildings. Or of course weather. It’s Hobson’s choice. People who have turned up don’t know you’re there. So obviously you have to stop what you’re doing. In the safest way possible to stay within the rules and regulations. We all know it’s not easy. It is a difficult choice at the time to consider. Keep flying regardless. I always have a plan b. Trouble is you can overthink things.. when you are there. We’re all sensible. Drone pilots. Experience always prevails.
But if you need a ‘rule’ to follow for crowds in the A1 category, the 1:1 rule would be a sensible one.
Yet “shopping areas” is the first example given in the Drone Code of places to expect crowds.
I guess it would depend on the shopping centre.
Westfield in Stratford = crowds, Whitgift Center in Croydon = no crowds.
Post Covid, the local one to me would love it to be that densely populated .. these days it’s less populated than a morgue! Most units are empty.
Taylor Swift shot the music video for one of her recent songs at Whitgift. Her fanbase was all “Oh look how great that is, she found the perfect abandoned shopping mall with that lost in time vibe and bussed in those extras”, and we had to tell them "No, that’s just Croydon on a weekend, that place is open as normal.
I will never understand the formatting on this board, lol
In fact, it’s what the CAA specifies in PDRA01:
  • Horizontal separation between the Unmanned Aircraft and assemblies of people must not be less than the height of the UAS (i.e., the 1:1 rule).
I was under the impression PDRA01 is geared more towards the specific category rather than the open category.
From the Drone and model aircraft code :-
Its all here page 15 & 16
Lots of ‘should’ in there and not many ‘must’
Interesting outcome…
Just for completeness, that graphic is from the end of section 4, which is entitled, “ Do not fly closer to people than 50m”
Here is the graphic from section 5, which covers crowds of people, rather than the general “people”
Indeed, but gives an idea of what the CAA’s thinking is on distances and crowds… which was the original query.
Very true.
I can absolutely understand the confusion that has lead to the thread being created, given that the CAA haven’t placed a distance on the graphic for crowds, leaving it rather ambiguous. That’s why my initial response was more towards applying critical thinking with an overview rather than searching for a specific. My position is that if there was one to be found, the CAA would already have stated it in plain terminology.
Similar to how when they talk about sub 250g drones the guidance merely states that the distance between your drone and uninvolved people may be reduced without becoming illegal. But it doesn’t state how much it can be reduced by, or to what. That’s left open for pilot interpretation, which we do using the other information found in the same contextual scenario.
They do say that you should use the 1:1 rule.
If you fly higher than 50m, you should keep the same distance horizontally. For example, keep 80m away if you fly at a height of 80m.
Surely you would give a crowd of people at least the same clearance as a group.
