Hi, I have a Mavic Air 2 which I’ve flown six times.
I had something flag up on my mobile ‘Gimbal Camera Overload’ which is unheard of, as the camera is free from interference. I am always careful to pack it in the semi-rigid case, use the gimbal protector all times during storage and no hard landings whatsoever.
Have anyone had the same issue? I hope it is not necessary to send it to DJI for an examination.
Hi FlyExoticaholic I’ve only ever had this when I have turned on the MA2 with the protector still in place when I forgot to take it off and also when I turned the MA2 on while on the floor in longish grass. Does it move freely when the drone is turned off?
Trimmed grass as I used the football pitch. Started using a landing mat today. From my hand - no way!
I didn’t know the gimbal camera mechanism was so sensitive to a little bit of dirt. It looks like I will avoid taking off from trimmed grass but stick to tarmac and landing mat for other landing conditions.
I’ve never really bothered what surface I’ve taken off from (other than water ), and never used a take-off pad. Never had any related problem.
Also of interest in that respect is the number of people that say “Oh - you’ll clog up the cooling fan with dust!”.
My fan failed, for whatever reason, but taking the MP significantly apart to replace the fan, one thing was very obvious. There was absolutely no build up of dust anywhere.
There are photos of that “discovery” somewhere in the Modifications thread.
Sorry was just having an Indian takeout. Have you tried recalibration the gimbal? And if so did it calibrate without errors? Yes the gimbal does seem to be quite sensitive but to be fair it is a delicate precision piece of equipment so you definitely need to take care of it
I’ve had this only when turning on with the protector in place, or when I changed the filter with the drone powered on. The latter makes me think the gimbal doesn’t like any manual movement when it has power
