Hello! I have a specific need to make a battery pack out of 18650, it needs 12v and 2a output.
I know there are many ways to make the battery pack, I was looking for ready solution that can
have 3-4 18650 lion batteries
be able to safely balance charge via 5v Micro USB or USB-C port
provide 12v and 2a output, nice to have one spare 5v output.
pre-made shield as much as possible
I came across this 18650 battery shield that provide four 5v 2.2A, and four 3v 1A output.
I wonder if it is possible to safely convert it to output 12v 2a? Any experts can help/advise would be much appreciated! thank you in advance.
If you want near exact 12v, you’ll need a small regulator. Pretty cheap. But you’ll probably need at least 5 cells to run it unless you boost it. But there may be a ripple on the supply if you do boost.
If a voltage regulator (or voltage step up can help), just wondering how to wiring it with this battery shield - because it only outputs 5v 2a per power source pin.
