I paid a visit this evening, and here’s what I found.
From the countryside end, they’ve closed the gates. It’s chained up with a combination padlock.
To the right, there looks to be an easy hop over a wall.
But the wall is covered with said anti-climb paint (yes, I put my hand in it
) , and it’s a good 7-8ft drop on the other side.
To the left, through the field, are low, dry-stone walls, which look a bit more manageable.
But it’s still a reasonable drop on the other side, and thick with brambles.
(This looks more daunting in real life, trust me.)
Approaching from the Sainsbury’s end, there is easy access on foot, despite the gates and fencing (which now stands wide open).
But after a 10 minute walk, you’ll find they’ve fenced off the other side of the site, pretty securely, with fence panels covered in the same anti-climb paint.
However, about 20 feet to the left, the green railings just stop and there is relatively easy access to the site, although you would have to make your way through several yards of fairly thick undergrowth to do so.
In conclusion, they’ve clearly made a concerted effort to keep people out, and we can no longer enjoy the easy, open access we once had.
If you were determined, it wouldn’t take much to get in; a tarp and some collapsible ladders at one end, or a bit of a hike and a few scratches as you push through the brush at the other. But whether you believe the site is surveilled as closely as advertised or not, I can’t imagine the reception would be as casual as it has been previously, were you to be discovered.
It’s a shame, but I don’t think I’ll be chancing it.
