Mavic 2 battery won't turn on
hmm that is what i thought
Yes
@milkmanchris do you think I should buy a new one as well as getting the broken one repaired?
Can u repair them ?
I’d speak with DJI didn’t you get it at Christmas ? Can’t have that many charge cycles
You have a good memory I did get it at Christmas. I’ve spoken to them and they said that I should send it to them to get it repaired and if they can’t repair it they will send me a replacement one (hopefully it is new).
However, do you think I should get another anyway?
Charge cycles: 14
You can never have enough batteries :wink:
£139 :thinking:
Batteries do naturally deplete when not in use and I was advised not to let batteries reach 0% or they can die. Not sure why (sure someone else can explain this, if it’s true), so I’ve got into the habit of charging after every flight. I know this doesn’t help you now but…
Ah, that’s what’s happened in my case, I think but I am not sure then so is it not repairable?
Honestly, don’t know. If you get it running will be interested to know how. Good luck. They’re not cheap!
No, I haven’t been able to get it running I think it is dead :skull:
Good luck Alex, your new battery will be nice and shiny
Yep I am going to send it off and buy another so I’ll be up to three!
PSA: DONT LET BATTERIES GO TO ZERO BY THE SEEMS OF THINGS
With car batteries that go below a certain voltage, a charger will not charge them unless you put a good battery in parallel with the one you are trying to charge. Not sure if you can do that with an “intelligent” battery.
I don’t have a car charger, unfortunately. I’ve ordered another battery and I think it is due to arrive on Wednesday. I’m also going to send the faulty one to DJI tomorrow.
