Mavic 2 battery won't turn on
I had a flight with my mavic 2 Zoom the other day and landed at 30% I think and now a few days have gone by and I have plugged in a battery to charge however no lights showing even when I press the button. However after importing the photos the battery was at 0% and turned off automatically
How long has it been on charge for?
May have just gone in to hibernation mode - recent thread here: Batteries down to 50% - #14 by MementoMori
Shout if it recovers and we’ll merge this thread in to that one.
If not, keep this one going :slight_smile:
It’s been on for about a hour or so
Try the press and hold for 30 seconds thing
Tried that and it doesn’t do anything
Do you have a car charger you can try?
No I dont
I’m out of ideas, sorry.
Might be dead :slightly_frowning_face:
Yes that is exactly what PFS said as well
Can you not fit it to mavic, plug in usb to pc? And see if that wakes it up? Or then try assistant 2.
Hey Alex. Any change it was trying to install the new firmware when it died?
Saw this video of a fix if it happens on a Mavic Pro, using DJI Assistant 2 to force the update back on. Might be worth a look to see if the same could be done on a Zoom?
Failed Firmware Update Killed My Battery, Here's How I Fixed It - YouTube
I done that
ok im charging a spare and ill do a refresh of the firmware
@JoeC I had a flight with rthat battery after a firmware update though - all was good but not now
Ah, probably not then. Still, worth plugging it in to see if it even sees it. May just be an ex-battery :frowning:
ex-battery???
I mean it’s possible it’s dead. :frowning:
Im refreshing the firmware do you think it will help?
Can’t hurt. :crossed_fingers:
Remember each battery has its own small update so do it with that one plugged in if you can.
In better news, better to die on the kitchen table than mid air ;o)
