I’m having a mental block here guys or I’m just thick lol, so please help me out.
I’m selling my Mavic 2 Pro so I’ve been trying to find out how to unbind it from my DJI account (are M2P’s even bound?). When I sold my Mini 2 recently I was able to do it through the DJI Fly app, but I can’t find this option anywhere in the GO4 app.
Anyone help or has even done this? Thanks in advance!
I cannot find anything in the Go4 app that even mentions Device Management. It does show my DJI account details, as it needs that to sync. So the process that I posted above is not applicable to Go4, only the Fly app.
TL;DR … I don’t think you need to do anything like unbinding on the M2P/Go4 … apart from remove SD card, clearing any internal storage (if applicable).
With the Mavic 2 Pro/Zoom you need to reset it using DJI Assistant 2. Once in Assistant 2 - select the Mavic 2 and then select Firmware Update. You should then see the Factory Reset option - select and then select confirm. After all is done select Complete. This method removes all your data and links with the drone.
If you do not do Factory Reset then all the flight times etc that the new owner puts on the drone will be added to your DJI account as it will still be linked to your account- it won’t stop them from using it though. Having said that, it doesn’t mean that DJI won’t introduce some kind of restriction that could cause problems to the new owner at some later date
Personally - I’d/will reset my M2Z when I sell it - just for peace of mind
Hi John @Jhdee sorry, just ignore my last post. I tried an earlier version of Assistant 2 and it has the Restore Factory Defaults button, it seems to have been removed from the later version for the Mavic.
I initially downloaded DJI Assistant 2 (version 1.2.5) then noticed there is a version specifically for Mavics but is version 2.0.14 but it hasn’t got the Restore Factory Defaults button that is on the earlier one. I also noticed on the DJI forum folk asking why it had been removed, but typical DJI, their answer made no sense.
