As I have a lathe I can make my own joysticks however not sure what the thread size it is. It looks like a 6mm and would assume it is metric but coarse or fine?
Mavic Mini controller?
Are they not all the same?
Who knows?
The M1P don’t even unscrew!
I can confirm that the Mavic Mini, Mavic Air, Mavic 2 Pro are all the same.
I have just tried the knobs on each, and they all fit each other.
I would say they are M6 Fine thread from my Engineering background, but, this is unconfirmed.
Hi I have a construction background & a M-air
What is affectionately call a gutter bolt is M6 Coarse and although it will start to fit in it is NOT the Correct thread so I too believe it is as stated above
Hope this helps
This is what I’m referring too just to be clear
Mockingbird, thay havn’t, its fine
Or American Imperial Spent many hours trying to spin nuts on the wrong way
So my American Cousins it sounds like I don’t like you That’s not the case it’s just you speak a similar language to us but think so differently And I get so confused so easily
