Mavic Mini 3 pro propeller screwdriver
Hi Guys
I have a little chip on one my Mavic Mini 3 pro propeller
I can’t remember when purchase it came with a screwdriver to change … check the box but nothing there. Is there a way to get one or purchase one …
Can’t use drone till I change it … and it looks so fiddlely to change propellers. compare to the Mavic Air 2s
Thanks. Steve
One was packaged with the spare blades in the fly more package.
You need a PH000 one, I believe - so maybe your set will have one.
I’ve got this set that has been ideal for me over the past few years. It’s a knock off of the iFixit stuff, but it’s stood up to the test really well. Includes a 000, as well as lots of other fiddly sizes and security bits.
Having said that, you should have got one with the drone but it’s tiny so may have gone walkabout.
Thank you . Just purchase on Amazon :+1::cucumber:
I did look it up, so hopefully it works.
Enjoy your drone
Hi : well…just found the screwdriver that came with the drone .:thinking:. I won’t canc Amazon purchase . Best to have 2 of them … thanks again :+1:
The screwdriver that came with drone … is actually awful :cry:. No grip on the screw … any force I will damage … this is not going easy Await for amazon screwdriver …
read that as well :joy: :joy:
Its a screwdriver…! try Poundland… or wait until you pull your crackers on Christmas day, there is always a screwdriver set in them… :smiley:
Receive the screwdriver. Great :+1:. Thought I change all the propellers for new ones … BUT. One set was so tight that unable to unscrew :cry::cry:. Now looks like I dent the screws … Arrrr
They’ve all got thread lock on them :confused:
Ah man, who put those on?! When I swapped the props out on my Mini 3 Pro the screws were thumb-tight and the little screwdriver that came with the was absolutely fine for the job. :frowning:
Have inform DJI . Under warranty. So send to them
Unfortunately being Xmas period . So send after
as I said before … the other 3 sets of propellers was fine to unscrew . Just had to be one set to be so tight to take off
You’ll have new screws for the new props so even if they’re a bit chewed up when you get them out it’s fine. It’s they’re completely immovable though then yeah that’s tough luck.
