Hi Guys after a little advise. Sorry if this seem like stupid question
The guys I usually fly with are giving me conflicting opinions and that may well be the case here. But I figure if I have a majority verdict I can make a more informed choice
Not flown my drone for over two years due to illness, (COVID) finally up and about. As the titles suggests it’s a Mavic Pro 2. I was using DJI assistant 2 for up dating the firmware on the drone and the controller. prior to being ill, and I figured it would need an update having been left in it’s case for two years.
I now find the DJI assistant 2 is no longer supported.i.e receiving updates, but it does show that there are two firmware updates that I have missed. I realise I can also use the DJI Go 4 app to update the firmware but this where I’m a little unsure.
One of the lads is saying I need to install each of the upgrade in sequence finishing with the latest.
Another is saying No, you just upgrade to the lastest Firmware and everything will be “Tickety Boo”
another is say that becuase it been left so long that I should in all fairness restore the Drone to Factory Default setting and then upgrade to the latest firmware. Otherwise my drone runs the risk of malfuction and flying off into the sun set without me or worse falling from the sky like brick.
I searched a few forums and not been able to find the answer. Which of the three is near the truth??
I’m probably going to pick up a DJI mini 4pro, as this is more like a stealth drone compared to my mavic 2, but I did get my A2 C of C just beofre I became ill. So thinking I’m going to keep her as she really does do well in the wind
