I have to admit, the camo skins look cool, but from a practical perspective the Mini is going to be difficult enough to see at a distance without something bright. Let alone if you have to go looking for it should you have an unplanned landing.
How are you printing these @McSteamy2010 - is it a standard printer or something specific? I have looked at doing this as well but am not sure about the quality level I would need from a domestic printer. Are you using a vinyl sheet to print onto?
I do have just the standard vinyls in various colors,
Solids and chameleon also got some inkjet printable vinyl sheets (A3) this is all designed using coreldraw2019 and saved as an SVG or AI file them uploaded to the LiLu vinyl cutter for precision cutting.
It’s only a standard XP960 I believe, standard inks,
There are probably printers deigned for this out there but I’ve never needed the use for one, also can imagine there quite pricey
