Hidden away in the tiny village of Sheet, Hampshire is a little gem of a fly site, if luck is on your side ! Approaching Sheet from the Petersfield side, turn right down Mill Lane (VERY narrow) and work your way down to a tiny car park on your left, which borders the ambitiously-named ‘Millennium field’.
This field is small, overgrown, and unspectacular in and of itself, but the brilliance of this site lies in the huge allotments garden to the left and the very close proximity to the railway line at the far end (careful of that !). There will be ‘some dogs’, probably not on leads, and long grasses everywhere except the bits where the dogs pass, so bring a landing pad and launch off-path if you can.
How we fly here depends on whether you have been over to talk to people working on their allotments first ! If you are lucky, then there’ll only be a few people there working on their plots, and if you ask nicely they may agree to let you TOAL from the paths within the allotment (bonus, no dogs!), and allow close-pass flights over the gardens, which makes for exceptionally interesting footage of some very well-maintained little patchwork plots !
But if luck is not on your side the people you ask may insist that you have to write to the allotment co-ordinator, put signs up, get EVERYONE’s permission before you can fly, and basically it’s a no-go from them for that day ! In that case I inform them that I can legally fly from the field right next door, and they should expect drone movement in the vicinity, but that I will keep high over their allotments and not hover there for extended periods of time… The gardens still look amazing from high up, so it’s not a total loss if this happens, and still worth burning a pack on ! But if they let you down to head-height, then you can spend a solid hour filming this without much repetition !
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 09/08/2024. It remains the responsibility of any pilot to check for any changes before flying at the same location.
