Fly app gives a popup for battery firmware update, I click update and it shows at 70% progress immediately then after around 30 secs I get an update failed message.
I have three batteries, one does not give an update prompt, both of the others do the above.
DJI suggest sending the two back for assessment but if its a quick fix I’d rather not lose 60% of my duration for however long it takes.
This gets stranger by the minute. Previously deleted the Fly app on my phone, loaded an older version all to no avail. Then updated the Fly app again, tried to load the battery firmware on one of the batteries and it worked! The third battery is still failing to update - very weird.
Wrong, it didn’t update at all. Just decided to tell me that their were no firmware updates. Just restarted from scratch with the same battery and it still wants an update.
Thankfully it worked. Took a while to get Assistant to see the Mini 2 though. Had to change the USB cable which seemed to do the trick. Once again thank you.
