I think this work for holding the tablet in place but I just wonder if the steel of the ‘bracket’ would affect the tx/rx power or cause any interference issues.
Most decent mounts for controllers are mainly metal. The phone or tablet you are using with the controller contains a fair amount of metal. I think you will be ok
Thanks all. I’ll give them a go. I didn’t expect that they would affect it but its nice to be able to blame someone (s) else if it does!!
Think all 3 answers are the solution but I can only tick one box.
I use this one from Amazon £9 - it holds my iPad mini perfectly. SHEAWA Adjustable Remote Control Flat Stand Tablet Holder for DJI Mavic Air 2 Remote Control Accessories
Sorry mate scratch that thought, I’ve just seen the dimensions in the first post. In my head it was massive like one of those metal hangers that go over the edge of a bath tub
We will see. I fitted it yesterday to try and it felt OK. Slightly ‘top Heavy’ compared to the ‘phone only’ but then the tablet is much heavier on its own.
It was only £4.50 and if it is too heavy I can;
hang a towel on it in the shower room.
Buy the official DJI unit which looks really well designed (if expensive) as I ’ tried the cheap option, love but it just didn’t work’!
I already have a tablet holder with tripod adapter and 1m c to c lead for longer flights.
Well it works… except I over did the bending so t’was a little loose. Will rebend the bracket tomorrow and try again BUT much better experience with the tablet.
I made an I-pad hook from a brown plastic waste pipe.
Cut a section out then heat with a heat gun and flatten out. Cut to shape heat up and form to shape. Clean up and spray paint it black.
Glue a small section of rubber inside top tip to grip the I-pad.
Light weight and strong. Job done.
Would also work with grey pipe.
