I just did 7.75km in Atti mode, around home and a trip to Asda and back
Unfortunately, Pause does not work in Atti mode. But … holding the button will initiate RTH, which automatically puts it back into Normal mode and attempts to return. On a day like today (no wind), that would be fine. But my preference would still be to switch it Sports mode and RTH manually.
Correct. Switch to any other mode, other than Atti mode, will reengage GPS positioning and bring the drone to a stop (unless it is very windy, like 35+ mph).
Probably talking out my arse, but now you can adjust the EXP of the sticks, could this help get to ‘full speed’ quicker? Not sure its even enabled for sport mode.
@clinkadink if you were 20yrs old you would be called a yob. But because you’ve reached a certain age and have a beard - you’re like a scientist
Not the same watching the video knowing what the ending is. Kinda like watching Titanic.
Just glad you do these tests so we don’t have to.
There are far to many “Will it run” videos on YouTube. Time for some “Will it crash” or “Will it come back” videos
At the end of the day, if these Mini 2’s are safe enough to fly over people … I want to know their limitations. And if nothing else, these endurance tests prove that the Mini 2 packs a punch well above it’s weight, and is a very sturdy and trustworthy aircraft
Uhm. Read & learned your ways.
( yes, I re-bought a Mini2 - still waiting for legal advice for THAT guy ran away after crush - not crash ).
Made the tripod mode change. So I fly in S mode all time with good speed finally, maintaining GPS, and only over 100 meters high and away, I change in ATTI, wonderful wonderful thing, it howls @ 17 m/s.
The only perplexity is the braking…it doesn t work at all.
Maybe is there any parameter tweak to reduce braking distance ?
