Storm Malik has hit the UK, so I decided to see how the DJI Mini 2 copes with the wind and perform several speed tests
The speed test results have already been shared in the Breaking the Speed Limit thread. This video captures those speed tests, how fast the Mini 2 flew compared to DJI’s advertised top speed of 35.7 mph, and it shows what happened to my Mini 2 as a result
It is also explains why I was awarded the Plonker Badge
Disclaimer: I am sharing this for educational and test purposes only. I perform the tests in wide open empty countryside, with no-one and nothing around me. I do so at my own risk. I do not encourage that anyone tries this themselves, and if you choose to do so, I take no responsibility.
Speed tests markers in the video:
- 02:32 - 06 Feb 2022: Adam’s Grave @ 285m / 935ft
- 08:19 - 06 Feb 2022: Broad Hinton @ 192m / 630ft
- 10:35 - 06 Feb 2022: Hackpen Hill @ 272m / 892ft
- 13:48 - 06 Feb 2022: Barbury Castle @ 262m / 860ft
- 16:50 - 30 Dec 2021: Barbury Castle @ 262m / 860ft
ATTI mode is the mode that the drone switches to when things go wrong. Your drone may lose GPS reception when it flies near a strong source of signal interference. When this happens, you can suddenly lose the GPS stabilisation feature that you have heavily relied on.
Steps I used for adding Atti Mode to the DJI Mini 2
01: Register and buy you unlock license at Drone Hacks
02: Download the Windows 10 (or Mac) Drone Hacks software
03: Install and run it, enter your email and password
04: Get a USB C cable connected to your PC
05: Power on your Mini 2, as soon as it beeps, plug the USB C lead into the drone
06: If OK, it will say there is an available license to use, do you wish to apply it, select OK
07: Apply both Hacks on the Hacking tab, follow the instructions.
08: At this point I would perform a test flight, and make sure the hack has taken
09: Then, back in the tool with the Mini 2 connected, select the Hack Parameters tab
10: Then select the Advanced Parameters button
11: Search for ‘mode’, there should be 3 similar Flight switch position parameters …
- fswitch_selection|g_config_control_control_mode[0] = Tripod : factory value = 12 (Tripod)
- fswitch_selection|g_config_control_control_mode[1] = Sport: factory value = 8 (Sport)
- fswitch_selection|g_config_control_control_mode[2] Position (GPS): factory value =7 (Position)
12: Change Tripod value from 12 to 3, as 3 = Attitude Mode
13: Save and then select Write Parameters to Drone (or something like that).
For Steps 1-7, thats the basic applying of the Drone Hack, they have YT videos on the Drone Hacks website showing you how to do that. Very helpful.
