Mini 3 Pro No FocusTrack in 4k 60fps?
I was getting familiar with the Activetrack functions on the Mini 3 Pro yesterday and decided to try setting up a standard “follow me” feature. The drone refused and gave me a message about “FocusTrack” not being available because of the recording format. I was trying out 4k at 60fps and hadn’t realized that you can’t get this without changing to H.265 - I hadn’t changed this in settings, so assume that selecting 4K 60fps automatically changes these settings?
Is that right that some of the video features of the Mini 3 Pro are not available if you select certain recording specifications?
From
[DJI_Support ]
Additional comment actions
Hi there, please make sure that the drone and controller have been updated to the latest firmware version, you can refer to this tutorial and see if you can initiate tracking: DJI Mini 3 Pro | How to Use the Intelligent Flight Modes - YouTube
Please note that FocusTrack is not available while recording 4K/48fps, 4K/50fps, 4K/60fps, 2.7K/48fps, 2.7K/50fps, 2.7K/60fps, 1080p/48fps, 1080p/50fps, 1080p/60fps, and 1080p/120fps video. Make sure that the camera is set to the corresponding framerate.
I also edited the post to Mini 3 Pro
Ah, that explains it then. Thanks for confirming. Did I title the damned post incorrectly AGAIN? :face_with_spiral_eyes:
I just put in the title Mini 3 pro as it more searchable and edited your post from mini 2 pro to 3 pro :+1:
JEEEEEZZZZZ!
I just keep doing that. I spend ages making sure the body content is coherent just to F&*(k up the title FFS :exploding_head:
