Mini 4 Pro / RC2 error message battery power restricted
I had this pop up this morning, temperature was about 4C, the battery power as shown 43% and the max speed was then restricted to about 3m/s. I gave the warning a stiff ignoring until I got an RTH at about 22%. I can only think it was due to the temperature. Both cells were balanced when I check after the flight and the battery charged without any issue when I got home. I’m left wondering if I should be concerned (I’m not) and whether it’s a known issue. Thanks.
Between 4 and -10 degrees is what we call the “sweet spot” for icing problems to occur. It’s possible your propellers started to take on a little frosting, this subtly changes the shape of them which can effect their aerodynamic ability and reduce lift.
Thanks for that suggestion @GreenAJ, something to try to replicate as the days get colder. Next time it occurs, if there is one, I must RTH ASAP and have a close look-see.
When you take your A2 they teach you to send it up for about 30 seconds, land and check the props and make a decision based on that.
Bit of experimentation this morning. 3C/4C on the ground, took it to 75mtrs and threw it around for 5 minutes as energetically as you can throw a Mini 4. RTH and the props were as dry as a bone. The day felt a lot less humid and warm in the sun than it did the other day when I got the error message which kind of makes sense. Now waiting for a cold and humid day to try and replicate the error.
@Inca, it would be really useful if you could share the Airdata logs for this issue, it’ll help people provide you with a more detailed answer based on what actually happened.
If you’re not familiar with Airdata it’s an independent platform that allows you to aggregate your flight records and it also allows you to share logs with other people.
Here’s a guide on how to upload your flight logs to their web site / app:
Setting up Direct DJI Sync
Once your logs are visible in Airdata you can use this guide to share the log(s) in question:
Once you’ve created the share on the Airdata web site simply reply here and paste the URL, someone will then take a closer look for you.
Thanks for that suggestion @sparky, I’ll give that a go once I’ve got my head around the instructions. My IT skills hover (rather an apt choice of word) around the Neanderthal level, thankfully my one device, an iPad, keeps a weathered watch on me.
