Hi
Is there anyway to calibrate the downward senses on the mini 4 Pro drone …?
Reason is. That I can’t land my drone when to RTH
Even thro the area is completely free of obstacles drone just hover above ground … I even place the throttle down for 5, 10, 15 seconds it won’t do …and I even turn off the obstacle Avoidance on the RC2 still won’t land … is this another balls up on the latest Firmware update from DJi. ! Steve
It’s not possible on the Mini 4 Pro,
I would raise a ticket with DJI and return it for warranty repair
or if bought locally return it to them as faulty
I normally just flick the drone into sports mode to hand catch my Mini 4 pro. Not sure if this will help with your issue, but might be worth a go?
Hmmm …never thought of that putting in sports mode
I try that tomorrow see how it go
Beware …. It may land very quickly
Did you make any progress with this issue, @Tooting37 ?
Hi . Nope I send to DJI for repair later this week
Try many times now. Just won’t land when RTH
Just hover above ground . Using throttle stick on R/C to land for 5, 10,15 sec but unable to land had to use my finger or stick press to ground … seems like Obstacle avoidance stopping me to land Apart from this everything else on the drone is a ok …
Hi : just an update on my issue for mini 4 pro not landing while RTH .
Drone sent DJI Netherlands … they said there is fault with the drone … and this morning received brand new mini 4 pro. Wow … never thought I get a new drone
So all good
Probably a refurb they usually are, but still a result
